Am I hurting my I/O starting it on the ramp?
RinkerFamily
What damage if any am I doing to my Merc. Alpha One I/O starting the boat on the ramp just out of the water? Typically I run the blower while we uncover the boat, take tie downs off and load the coolers and kids in the boat. I drive the trailer and back it down to the water's edge and then unhook the bow strap, hop in the back of the boat. Then I yell to my wife backing the trailer the rest of the way in to wait until I make sure the boat starts....nothing like floating off the trailer and then jacking around with getting the boat started and drifting into others. Anyway, I get the boat started and then I just yell, back her in and within 20-30 seconds the lower drive unit is in the water. Am I damaging my impeller or anything by doing this....running the enginer out of the water for those 30 seconds? Thanks.
AaronG
Re: Am I hurting my I/O starting it on the ramp?
Yes, running the impeller dry will quickly ruin it, even only a couple seconds. Wait until you are in the water to start the engine. I'd also change out the impeller now that you've run it dry a few times, or at least change it out this winter.
QC
I agree TOTALLY with Aaron. How old is the impeller? It may be due to be changed anyway . . .<br /><br />You can still run it before she floats off. Just have your wife back it down until the ventilation plate is covered and then start it. The boat should not go anywhere at the point that the water intakes are first completely submerged.
QC
BTW, just a tip . . . You'll get some people a little cranked up if you post the same question in multiple sections. The proper place is probably the Merc/Volvo section, but this one is a very close second if not a tie for first. Oh whatever, but you get the picture. ;)
umblecumbuz
Rinker,<br /><br />One thing I don't understand.<br />Why don't you have a line from your boat to the trailer, or throw a line to the dock?<br /><br />That'll keep your boat from floating away, and you can take your time starting the motor in the water.
milkyway
How about the engine water pump? I think what you need to address is why you don't have the confidence that your engine will start.
salty87
yes. doesn't seem like you're gaining much but you are risking alot.
M
Mod3
Guest
From another post.<br /><br />RinkerFamily <br />Cadet <br />Member # 51890 <br /><br /> posted July 29, 2005 11:36 AM <br />--------------------------------------------------------------------------------<br />What damage if any am I doing to my Merc. Alpha One I/O starting the boat on the ramp just out of the water? Typically I run the blower while we uncover the boat, take tie downs off and load the coolers and kids in the boat. I drive the trailer and back it down to the water's edge and then unhook the bow strap, hop in the back of the boat. Then I yell to my wife backing the trailer the rest of the way in to wait until I make sure the boat starts....nothing like floating off the trailer and then jacking around with getting the boat started and drifting into others. Anyway, I get the boat started and then I just yell, back her in and within 20-30 seconds the lower drive unit is in the water. Am I damaging my impeller or anything by doing this....running the enginer out of the water for those 30 seconds? Thanks. <br />--------------------------------------------------------------------------------<br />Posts: 13 | From: Bloomington, IN (Lake Monroe) | Registered: Dec 2004 | IP: Logged | <br /> <br />spartanpele <br />Petty Officer 3rd Class <br />Member # 61130 <br /><br /> posted July 29, 2005 12:30 PM <br />--------------------------------------------------------------------------------<br />Yes... I wouldn't do that. You need that water to keep everything cool and to keep the impeller from spinning without the water. You're going to wear your impeller out faster without the water.<br /><br />I'd recommend doing it like everyone else...back it in, submerge your lower unit, then start it up. If you're having problems drifting into others, have the wife and kids hold the mooring lines while maneuvering the boat into the water.<br /><br />Everything I've ever read has said... don't run your motor unless in a body of water, tub, or muffs... <br />--------------------------------------------------------------------------------<br />Posts: 80 | From: midwest | Registered: Jul 2005 | IP: Logged | <br /> <br />DJ <br />Supreme Mariner <br />Member # 5471 <br /><br /> posted July 29, 2005 01:06 PM <br />--------------------------------------------------------------------------------<br />It will ruin your impeller, if it already hasn't. You are setting yourself up for a very bad day.<br /><br />--------------------<br />We're all here, because we're not all there!
M
Mod3
Guest
Moving to I/O questions.
tommays
if you have been doing this theres no way the pump is still good<br /><br /><br />damage starts in about 8 seconds on a dry run<br /><br /><br />tommays
rogerwa
I don't unhook the bow strap until I am ready for the boat to come off. What I do is back all the way into the water. Start the motor and then go forward to unhook the strap. After strap is unhooked, I will then put her in reverse and back off the trailer. I have rollers so bunks may work different.<br /><br />If worried about starting I would do it at home with the muffs before I left.<br /><br />You also need to make sure the drive is down in the trim range so you don't damage your joints..
CATransplant
What I do with my outboard is start it at home, complete with water, if it's been more than a week since I've used it. <br /><br />Then, at the ramp, I launch, then start it at the courtesy dock. I know it will start, because I started it earlier that day. Actually, it has never failed to start.
Scaaty
Seems simplier to tune up the boat so it starts with confidence (yes, you are doing damage)
thunderroad
I'm with CATransplant. Although mine hasn't yet failed to start, I start it on the muffs before I leave the house. At the ramp I do like most everyone else, back it in the water, start it up, have my girlfriend unhook the bow strap and park the truck/trailer while I orbit the area a little to make sure everything is good. Then she walks down the bank complaining about the rocks, the mud or the heat and we head out for a joyous day of boating.
jlinder
I agree with starting at home. I put the muffs on and run it until the engine is at temperature.<br /><br />That way I know the battery is charged, fuel is in the lines, and the engine is still a little warm by the time I get to the ramp.<br /><br />If I have a problem in the driveway it is a lot easier to fix it there before I drive to the lake.<br /><br />At the ramp it starts up first time every time. Really cuts down on frustration and ruined days.
Phantom17
I run my boat on the hose in my driveway before I go out for the day. I got a peice of hose and put a spiggot in the middle of it. I can turn the hose water on and off from the back of the boat instead of going back up to the house. <br /><br />Part 2. replace your impellor, unless your looking to pay some big bucks for a tow......
Stinger313
I cant believe that it still pumps water after being run dry so many times.Never run the engine without water to the drive, even for a few seconds.Water lubricates the rubber inpeller in the lower unit.
