fast94impala
- Aug 8, 2004
- 19
After obtaining a few tips from this forum, I changed the gear oil in the drive assembly today. I did however encounter something odd and wanted to see if it was "normal".<br /><br />After opening the air vent and the lower drain plug, the gear oil oozed out until the resevior was only 1/2 drained. Then is stopped. I pulled the resevior off to clean it and tried to simply blow into the hose that I had disconnected. No air would go in??? Clogged?? or is there some sort of one way pressure valve in the system? Should all the oil have drained out of the resevior?<br /><br />I landed up emptying the rest of the resevior to get rid of the mucky stuff on the bottom and resintalled it. Then I filled drive backup using gear oil pump through drain plug until the oil came out of the vent hole. I then filled the resevior back up.<br /><br />Based on the trailer/driveway combo, I could not get the drive perfectly level. It was at approx 10 degrees tilt up. Could that of had something to do with it?<br /><br />Any help appreciated.<br /><br />Thanks,<br /><br />Mark
