Alignment tool stuck
Jakem
Ensign
Good day fellas...I have managed to get my tool stuck....again....gen 1...it fully slid in to coupler and its cam back a bit but now stuck and I can't remember how I got it out before. Help please
alldodge
Might try bumping the starter and retry to remove.
Did it take much force to insert?
Should always use 2 fingers, if it takes more then that to go in, stop and remove
Jakem
Ensign
It went in pretty easy . Definitely didn't have to fight it in. I haven't re installed all my wiring yet
ScottinAZ
Master Chief Petty Officer
im betting its suction holding it in with the grease..... My tool has provisions for a screw in eye in the end of the tool.... perhaps yours has the same.
airshot
Did you make an adjustment to a mount with the tool inside ?? That will often pinch them in place.
Jakem
Ensign
No adjustments no....I'll try the starter bump and just keep working at it
alldodge
Can tie a rope (chain is better) to the bar and tie other end to something a bit heavy like a sledge hammer. Now pull it quick away from bar. You made a slide hammer puller
Jakem
Ensign
Alright I'll give the slide hammer trick a go...I hooked up wiring and bumped starter...didn't help...boat started though lol. It seems really stuck...
Jakem
Ensign
Ya it ain't coming out...I don't get it...shall I raise or lower engine mounts ...
Bt Doctur
Did the drive come off very easily? did you replace the gimbal gearing?
try tapping the tool end in all directions ,then pull
When removed drill a hole in the end or drill and tap for a eye bolt
alldodge
You could try but the problem is you don't know which way is correct
Slide hammer works better with a chain but its getting the chain to hold
Jakem
Ensign
The drive came off easy and I didn't change bearing. What did change and I should have mentioned is the transom has been rebuilt. I'm guessing the holes are off a tad. Can't be much though or it wouldn't have slid in relatively easy. I'll weld
cyclops222
Can you drill & tap a threaded hole for a 1/4" or 5/16" eye bolt That will help to yank very straight.
Do you have Rubber or plastic gloves ? Yes Put them on. Then TWIST and PULL at the same time. A drop of oil right where the friction fit in the transom is. Will help reduce the " PINCHING FRICTION by the transom.
