I have a 2000 Bass Tracker boat that I use to bow fish from. I currently have a 43 lb thrust Trolling motor (12v) and have two batteries in the compartment for the TM and one to start the 40 hp engine and run the lights etc. What I am doing is trolling for serveral hours and then when it goes dead opening the compartment and switching the cables and off I go. It is kind of a pain but I don't know how to change it or if I should change anything. I should mention that whichever battery is hooked up to the troller I can plug a courd into an extension cord and charge it without removing it. This is very cool but only works for one battery now so the other one I pull out and stick on my charger in the garage.
Oh and I recently added a third battery to increase my fishing time but there is not room in the comparment for another battery so I just carry a plastic battery case and pull one of the dead ones out and replace it with the good one.
How would you guys recommend that I set this up?
