Somewhat of a newbie here, have been lurking for some time now. I am in need of guidance on the next step for our motor. Bit of history, bought boat off of craigslist (I know, I know) this spring. Boat has a 1990 Johnson 115HP V4. We took boat to local marine mechanic to have prepped for summer use.
Items mechanic looked at/fixed:
compression 125psi all cylinders
new water impeller
replaced bendix (starter-flywheel gear)
We began to use the boat and noticed bogging conditions upon acceleration due to the previous owners lack of use. We have driven several times to get rid of old gas and have run roughly 3 tanks of fresh gas through the fuel delivery system.
This past week we had the same mechanic rebuild/clean the carbs. Mechanic said that bowls of carbs were plastic and warped and were allowing air to enter the fuel delivery system. (We replaced with metal bowls) He also checked the gas tank line and bulb, in good shape (I guess), they passed a pressure test.
We took the boat out today (first time after carb rebuild). The boat now has nice low end torgue. The problem comes in the fact that it seems very senistive to starting, flooding, and non-starting. We had it beached upon shore today and had a really hard time getting it started. We did get it started once we let it sit for about 20-30 minutes (fired right up, assumed flooded). We then pulled a tuber for about 30 minutes, stopped, let it idle in nuetral while we switched tubers and it killed(it idled smooth as can be for 3-5 minutes while we got the tuber setup). Couldn't get it started and had to be towed back to dock, trailered it, went home.
I am thinking something is wrong with the rebuild of the carbs or idle is set to low? Any other ideas or things to have the mechanic/myself look for?
new water impeller
