MalibuMike
- Dec 29, 2020
- 137
I'm about to pull my outdrive and have a good understanding of how to do it. I have a few questions but will also post what I'm going to do if you have any advice.
My plan is to change the gear oil, build a stand, and remove the drive. I've watched videos online and it seems straight forward. I will be pulling the duo prop and adding marine grease to the prop shaft. Disconnect gear shifting cable and remove 6 bolts .
Once the drive is off Ill be inspecting the ujoint and lube with a grease gun if it is good or replace if necessary. I already have an OEM one ready to use. I'll be replacing the two o-rings on the part of the shaft the slides back in to engine. I see that there is a rubber gasket around the water tube and will replace that. Ill look for any signs of water intrusion.
Here are my questions. I've believe that there is no gasket between the outdrive and the gimbal housing. Should I use any type of sealant? If the gimbal bearing was replaced 18 months by a reputable shop, is it likely that it is a non greaseable one or do all new ones have a way of being greased? Will it even be accessible with the rubber bellow still attached? For reassembly, I will torque the 6 bolts starting at 25ft pounds then up to 50 ft pounds.
Am I missing anything?
