Noticed some gear lube coming out of my water intake, so having the lower unit seals replaced.<br /><br />My question is how do you remove the oil seal cover (plastic plate over the drive shaft holding the seals in). Does this require a special tool or do you just replace the cover with a new one when you remove it?<br /><br />Any tips? <br /><br />Thanks,<br /><br />1stlite
