I just picked up a 9.9 four stroke model number EIOFEXEOC. I want to use it for a kicker on my 2005 Trophy 2052, with an OMC brackett. It appears that the motor will only tilt down to a state that is about 10 degrees up from parallel to the mounting plate. I need it to go down as far as possible to get the depth since it is only a 25" shaft (not 30"). It seems as though it should go down to past parallel but I do not see a way to do it. Ideas? Thanks
