Ok, so I have a 1997 Mercury 90 hp 2 stroke oil injected. I bought this last fall and am somewhat unsure of the history or maintenance practices by the previous owner. It was used on 2 outings last fall without issues before being stored for approx 6 months (stored with a full tank and marine stabil). I ran it on muffs a couple of times in between. I got it into the river for the first time and it ran for about 5 minutes before the rpms would drop from 5000-5500 to about 1500-2000 rpms in 1-2 second spurts 1000 rpms at a time. Even at an idle the motor wasn't sounding quite right. Gargling a bit?? I was able to get back to the dock at low rpms, but any attempts at WOT will quickly drop off. A visual at the fuel lines looks good (no obvious cracks or leaks). The primer bulb does not firm up the way I'm used to, but I can feel the fuel moving through...I then unhooked the fuel line from the engine and gave it a few pumps then re-attached. After this I decided to give it another go and everything seemed fine. Topped out at 5500 rpm's all day long. I ran it again the next weekend for 2 days straight, now just assuming it must have had bad fuel that sat in the fuel lines. A week later after cruising around for over an hour at 4000 rpm's, it happened again. This time I'm out on choppy water. Again the engine doesnt sound quite right. Idling normal and not really labouring, but almost sounded like gargling. For whatever reason, my trim decided to start acting up and is trying to trim down???? I have no idea if or how the 2 things could be connected, but I'm mentioning it anyway (I've never had any issues with the power tilt/trim). So I disconnect the battery to stop the trim, disconnect the fuel line, prime it a couple of times, then reconnect the battery (trim is now done acting up), and then reconnect the fuel line. Start it up. Sounds great, runs great. I take the hour + trip back to the marina with no issues. ..and that's where I stand now. There's a problem, and I have no idea where to start looking. Hoping someone can point me in the right direction, before I start spending...I have a solec manual that wasnt much of a help in diagnosing the problem.
