Re: 90 Johnson runs great, then won't restart
When it doesn't start check the basics, fuel, spark and compression. Check the FAQ's for a sequence to check. Something gives out when it's hot, you've got to find out what it is. Mine was ignition. One bad wire and a rusty magneto. If you suspect gas starvation, squirt some in the carbs and see if it fires.
