Re: 90 johnson 90HP VRO Spark Plugs
The Magnetor Capacitance Discharge ignition systems which came into being in 1973 have used the .040 gap right up through the years until some point.... apparently 1990 if that's what your manual states, and this .040 has proven to be what what was needed.<br /><br />Why the gap was changed to .030 I have no idea but it has caused some confusion. Boaters with the older engines have used the .030 gap and that has caused ignition intermitent problems, various problems, that when the gap was changed back to .040.... those problems vanished.<br /><br />Many of the newer engines (1990 up) have also met with problems using that .030 gap (not all), but when the gap was enlarged to .040, those problems vanished.<br /><br />Bottom line.... if .030 works for you, fine. If any kind of problem exists (idle, high speed breakup, etc), try the .040.... worth a try.
