L/U leaking, pulled the bearing carrier to check the seals but the propshaft and the floating brass O rings will not come out. There is a metal oring with two ears on it that doesn't seem to want to budge. Any suggestions? The seal on the front of the bearing carrier seemed fine, just loose as it should be. Cant find the source of the leaking yet. Help. TIA.
