Staticride
- Mar 5, 2016
- 22
e120tlcca vro (Oil tank removed, sensor unplugged and port on pump closed off)
My 88 VRO will get up to plane just under 4K RPMs and then back off down to 3K RPMs all by itself. If I leave it at WOT it starts surging, like its getting a burst of extra fuel and wants to go, then chokes down and looses power, then repeats. If I squeeze the fuel bulb repeatedly I can run at 5K RPMs smoothly.
Here is what I have done so far:
Checked compression good
Swapped power pacs (thinking SLOW mode was kicking in)
Checked that I am getting spark from all coil pacs and cleaned grounds
Put in new Carb kits
Put in new Champion plugs gapped properly
Checked for overheating
Made sure fuel take is vented properly
Changed out fuel, new oil and used sea foam
Installed Racor fuel/water separator
Replaced fuel line from tank
Replaced inline filter at fuel pump
Replaced squeeze bulb
Took apart the VRO pump and checked the fuel side diaphragm for holes/ tears
Non of the above has helped
Please HELP!
Please HELP!
