Hello, I have an '88 5.0 L Cobra and am having some dificulty with it dying suddenly. I learned through searches that there is a resistor in line from the Alt to the pos side of the coil. I checked my voltage at the pos side of coil with key in "on" position and only had 4.5Vdc. I then removed the wires on the pos side and found a full 11vdc with key in "on". Both ground wires from the neg side of the coil have good continuity with low resistance. The resistance from the PURP/RED (coil end) to the PURP (Alternator end) is .010ohms. Does this mean my coil is bad or the resistor is bad or what? Is there a way to test the coil through resistance? Any help would be greatly appreciated.
