Re: 87 Force 125 valve body help
does any body have a diagram for a force chrysler trim pump valve body need to recheck location of the springs that hold the BB's replaced the O rings on the check valves now down is up and up is nothing wont go down good news is it doesnt leak down any more is it possible the check valves are backwards ? took a pic of the bb location but not the springs
only way to make pump run "backwards" is to swap electrical connections. The oil tubes aren't long enough to reverse and the pump itself is incapable of lift pressure if the motor is spinning clockwise.
you should have three BB's of the same size in an '87. Put BB's into top gear plate and assemble upside down. Two holes equal and opposite to driveshaft get one BB each. Third hole is the loner. Drop the brass washer in first. Then spring. Then BB on top. Use a dab of vaseline or marine grease to hold BB in place. Lower lower body onto gear plate. Squeeze firmly with one hand while using a nutdriver to tighen a bolt with other.
Note - they aren't BB's. At a minimum use steel ball bearings. Precision stainless if you can since they are for fluid seal in a marine part.
Note - your pressure is set by shimming. do not change the springs or number of shims at any location unless you have the ability to measure and adjust pressure.
Note - don't ever, ever, ever take apart the top half of valve body at home. Only about half the people who try it are able to get their pump going again. If you do take it apart, then wait until after you have tried every other possibility first.
