85 volvo penta 270 won't stay down in gear
mhop79
what would cause an outdrive to lift up while in gear? trimmed all the way down with the dash light on you can pick up on the outdrive. I'm puzzled, didn't hit anything that i know of, and it wasn't like that before we winterized it. goes into gear and prop spins in both directions, but kicks up and the boat is unusable in its current state. as always thanks for the help.
Don S
Re: 85 volvo penta 270 won't stay down in gear
You have problems with the lock down mechanism. Worn, rounded over pawls that latch onto the cross pin is a common problem. missing or broken springs will also do it.
mhop79
does this mean the lower unit needs to come off?
Don S
No, it can be repaired while on the boat.
mhop79
awesome, is there another thread that goes into details of the repair on this subject? i searched but didn't see any, thank you so much
captmello
Nice to see a local VP owner and DIYer. Welcome.
That lock down system has brought many to tears...Not me, but many others.;)
Has it ever worked? Or did you recently purchase the boat?
In order to fix it, you need to get a good understanding of how it works. It contains many variables and if one part is not working, you get the situation you're in now.
A manual would help...
this is a similar thread with some useful info, also it contains a link to a 280 outdrive which has the same system.
Thanks to Don S! Check it out.
http://forums.iboats.com/showthread.php?t=316589&highlight=pawl+volvo+270
mhop79
its my brothers boat, has always worked great til now. we swap boats a lot, so needless to say we were both surprised not to see it working when we pulled it out of storage this spring. ill check the link, thanks so much for posting it. matt
