Re: 85 johnson advise
Hi, buzzking. Welcome to iboats.<br /><br />I'm not the prop whiz, but can advise you to test by tachomweter. Your engine should be able to run at a certain RPM at full-throttle. If the engione is in prime tune, and you cannot turn full RPM, you are overpropped. If you can exceed tghe Max RPM, you are underpropped.<br />So really, to know for absolute sure, You'll need a tach,and a tune-up,and a few test runs.<br />My guess is, the previous owner has asked his shop's tech for a better hole-shot,vs a higher top end for pulling skiers out ect. Chances are, the larger pitch prop will serve you fine, but do check to make sure you can get enough RPM. If not, you are loading the engine more than it was designed to be loaded. But standby here, we got several very bright prop gurus that may post additional help.<br />I just wanted to greet ya, and give you the basics.
