Re: 85 hp 1978 Evinrude Shift Linkage Adjustment
To start with, the shift rod has to be set to the correct length, which is: 1978 - V-4 model in neutral (L) 21-53/64? or, (XL) model in neutral 26-53/64?.
This is measured from the mating surface of the gearcase to the center of the hole at the top of the shift rod.
Once you have the shift rod set to the correct length, do this:
Take the spark plugs out, put the control in neutral and disconnect the shift cable at the engine;
Manually shift the motor into reverse and turn the flywheel clockwise to confirm reverse at the propeller;
Manually shift the motor into forward and confirm forward by turning the flywheel clockwise and observing clockwise movement of the propeller;
Manually return the gearcase to neutral and confirm by turning the flywheel clockwise while observing that the propeller is not turning;
With the gearcase in neutral and the shift cable still disconnected, move the remote control arm fully forward and back to neutral;
Using only the trunnion knob, adjust the cable until it will reconnect at the engine with no further movement of the the shift lever on the engine.
