8 hp Mairner
Lersia
Engine runs fine ideling and mid throttle..... When I gas on it on open throttle, the motor runs for about 2 minutes and quit.... It will crank back up in about 5 minutes.... Please help
JB
Re: 8 hp Mairner
Howdy, Lersia. The symptome you give are classic for an unvented or inadequately vented fuel tank. Loosen the cap and see what happens. If the problem goes away clear whatever is preventing air from getting in at the cap. If the problem doesn't clear up, pump your ball pump. If that clears it up you have a failing fuel pump or some restriction in fuel flow.<br /><br />Good luck.<br />JB
