'78 20' Grady-White Gulfstream
FreeBeeTony
Just bought a project boat, '78 Grady-White Gulfstream I/O. Has a 165HP IL6 mercruiser with no outdrive. I plan on rebuilding the engine and installing an Alpha One outdrive I hope to find fairly cheap. The hull seems to be solid, just needs to be cleaned up. I will try to post a pic.<br />I will probably be on here quite often for advice.<br />Any advice from the start? What should I do first? Should i go after the motor?
