Re: 75 Merc 1150 thunderbolt no spark
Ok. I guess the info so far is generic enough.<br />Something else you might check....Merc used this waterproofing goo around the base of some of thier distributors,and it's like a clear tar. It runs down over the years,and 'glue' the rotor to the inside of the cap,stopping it cold, and stripping it out. and can pool inside the distributor cap.Remove the cap, and with one finger (do not force it), try to turn the rotor. If it turns, that is your problem. On the earlier models (not sure about the single box engines), the rotor is not repalaceable, and the entire sub-assembly must be replaced! Dangol engineers!<br />But they tended to strip out at the distrib shaft and the plastic rotor's base. I was tempted to use marine tex or JB-Weld on them, but don't like pushing fate at sea...Still, i'll bet it would werk.While in there, make sure the timing belt up under the flywheel is still in one piece. They rarely break, but can.
