riverjet502
- Dec 28, 2006
- 116
OK guys
I was given a 71 9.8 merc. Just wondering... is the water pump impeller as easy to replace as it is on the same ara Jonny-Rude's? My question is does the shift linkage disconnect in the same manner as the Jonny-Rude's of the same ara with mechanical shift? It looks like merc uses a shift block on the linkage as well? Then the lower unit drops down off the lower housing. Or am I thinking wrong here.
