I tried to run my 20 hp twin merc outboard yesterday and found it wouldn't rev out. It starts, but appears to run rich. It is has a hand tiller throttle. Once started, it runs rough. It won't go into gear at an idle and so must be revved up a little. Once in gear it is doggy, has little power, and acts almost like the timing is several retarded. I stopped it and started it about a dozen times, in each case it behaved the same. It would not idle down to run at trolling speed. Whenever I tried that, after a 10-20 seconds, it would stall out.<br /><br />Does anybody have any idea where I should start looking?<br /><br />------------------<br />tj
