dancamp009
- Jan 13, 2007
- 64
I have a 1958 7.5 HP Evinrude long shaft that didn't run and had the old fasion dual gas line when I got it. Because it had compression and spark and I didn't have the original dual line gas tank, I converted the old style two hose system to a new one hose gas line the way they tell you how to do it at www.outboard-boat-motor-repair.com.
I get it running fine until I push the choke back in and then it conks out. I've cleaned the carb, adjusted and cleanded the points, get good spart, so I think it's in the gas line.
At first I became concerned because it didn't appear to be providing any suction (if anything it appeared to be pushing air out of the intake manifold) to pull the gas through the new fuel pump (Mukumi like in their picture). So I moved the plug from the left hole to the right hole behind the intake manifold to see if that would help create suction as it may have worked as now it will idle at high speeds while the choke is pulled out. It does smoke alot however. But as soon as I push the choke in, it stalls out nomatter how much gas I give it.
Another point. The fuel line conversion instructions call for adding single line fuel connectors (male and female) to the fuel line going from the tank into the fuel pump. I haven't yet bought the fuel line connectors, believing it should be fine temporarily just going straight into the fuel pump from the hand pump hose attached to the gas tank. Am I right in this assumption? Yes the gas tank is vented. Am I wrong? Are those inline fuel connectors neccessary to build up vacuum or to make the pump work correctly?
Any advise on this issue would be much appreciated.
thank you
DanCamp
thank you
DanCamp
