Fiftyfivefloater
- Dec 6, 2009
- 30
I finally got around to looking at this one as per forum member suggestions.
I have checked out the coils (visually) by removing the starter and looking into the porthole of the flywheel. I've attached some photos of what I could see. Everything looks very clean, crisp, no discoloration of any kind.
I did remove the carb and cleaned out the fuel bowl at the bottom. It did have some orange gunge in the bottom. The rubber seal for the bowl doesn't look all that good, wrinkled a bit but not torn. Since there was junk in it I am assuming that there must also have been some fuel in the Main Speed adjustment assembly. It probably needs to be cleaned out as well. But....all other parts of the carb look fantastic. The intake valves look minty as well.
One thing I have not been able to determine/locate, is the lower crankshaft seal. Not sure exactly how to go after that one. The recommendation was to for sure inspect it, but to safe it probably needs to be replaced (due to the fact that is a crummy seal to begin with). I see from my owner's manual where the drive shaft seal is located, is this offending seal? The owner's manual doesn't really show a seal between the upper and lower gear case, but it does indicate a seal on the drive shaft that is located below the impeller.
This is probably the point at which I probably need to order a repair manual, right?
