50hp mercury not firing
12Footer
Re: 50hp mercury not firing
Where to begin!? Well I would rule-out wiring first, checking all the connections at the ignition swith with wires removed.<br />Iginition and kill switches cause more grief with marine engines (when it comes to elctrical,zero fire) than all other points combined.<br />Disconnect the kill switch and try it before tearing-into the ignition switch (easier,and equally suspect).<br />If you still have no ignition, you may have to order a shop manual, and get into color-coded test points from the book, using the ol VTVM meter.
