50hp EFI diaphragm fuel pump pressure
Jeff J
A friend asked me to look at his 2006 Mercury 50hp EFI. Motor runs okay as long as someone pumps the primer bulb every few minutes. I think I have the problem isolated to the diaphragm pump but would like to confirm how much fuel pressure it should be producing. I am seeing less than 4 psi on the test gauge. I was expecting 15-20 but I do not the have a book for this particular motor. Can someone give me the psi I should be seeing?
Thanks,
Jeff
alldodge
Unable to say with 100% accuracy but finding it should be close to 42 psi
Jeff J
42 psi range would be for the high pressure pump sending fuel to the injectors. I am looking for the pressure going into the VST. It’s 19 psi on my 70HP Yamaha.
alldodge
VST on Mercruiser is 4 to 7 low side. Just needs to be enough to keep the tank full, similar to carb bowl
boscoe99
Where are you seeing a value of 19 psi? In a service manual or from an actual measurement?
Jeff J
I am sending the boat back today. The new mercury lift pump is putting out 3-4 psi which matches the old pump except for the needle on the gauge is steady now.
I attempted to order a manual for this motor through ebay but it got cancelled an hour after I paid for it. The vendor’s canned excuse was “out of stock or damaged”.
