5.5 johnson
Squeakit
Re: 5.5 johnson
I have an old Evinrude 5.5 which pumps water out of an opening in the back of the lower leg located about 10 or 12 inches down from the powerhead. This is called a tell tale and if no water comes out when your motor is running, your water pump needs repair - probably a new impeller at the least. You should NOT run this motor at all if it is not pumping a good spray of water out this opening. You will overheat the motor and do rapid severe damage.
Squeakit
Re: 5.5 johnson
Post the model number here and someone will tell you the year. I don't have the list of the model numbers - I think there is a website that has this; someone may give you that information also. Get a manual before you try doing any work on your motor. Good Luck!
Scoop
Re: 5.5 johnson
Here is a great place to look it up if it is older.<br /><br /> http://www.kencook.com/kccwww/marinepubs/oml12.html <br /><br />5.5 Hp<br /> Year Model Owner's Parts Service<br /> 1954 CD-10 376144 376230 302231<br /> CD-11 376280 376366 302231<br /> 1955 CD-12 376365 376397 302231<br /> 1956 CD-13 376576 376744 302231<br /> 1957 CD-CDL-14 376843 377018 302231<br /> 1958 CD-CDL-15 377169 377511 302231<br /> 1959 CD-CDL-16 377577 377805 302231<br /> 1960 CD-CDL-17 377858 378124 302231<br /> 1961 CD-CDL-18 378177 378458 302231<br /> 1962 CD-CDL-19 378506 378822 302231<br /> 1963 CD-CDL-20 379045 379268 302231<br /> 1964 CD-CDL-21 379202 380045 302231
ranroc1
Re: 5.5 johnson
I dont have the model # but the Serial# is <br />J 2 4 2 2 8 8 4 Do you know the year ? :confused:
Scoop
Re: 5.5 johnson
Sorry Ranroc, I was hoping you could find the model number. I do not knowof a way to get the year from the serial number.
ranroc1
Re: 5.5 johnson
ok here we go.<br />Model CD21-A #J2422884 can you here me now? ;)
JB
Re: 5.5 johnson
Hi, Ranroc.<br /><br />Your engine is a 1964.<br /><br />Good luck. :)
