Mr Rumblur
- Mar 30, 2011
- 32
After receiving some input about using Marine Tex to fix the cracked block, we decided to give it a try. Now we're addressing the overheat issue. It gets up to at least 210 and acts like it could keep going up while on muffs (all times it's ran have been on muffs).
We've replaced the impeller and the thermostat. While replacing the thermostat, we discovered RV antifreeze even though it's ran several times prior. I assume this means poor circulation so decided to check manifolds/elbows. There was very minimal visible corrosion. Is it common for there to be "hidden" corrosion deeper?
We also disconnected the hoses going from thermostat housing to the manifolds. A bunch of water came out of the manifolds. It appeared to have a little pink in it. Then we ran it briefly while still disconnected. At first, some water came out of thermostat housing, only under decel. When we ran it again, nothing came out. Isn't water supposed to come out of there? If so, is it only when it reaches thermostat temp? We didn't run it up to temp. Have we narrowed it down to the circulation pump? Thanks!
5.0gl pefs 4012048045 3869056
