spdracr39
- Aug 30, 2010
- 1,238
I have all the symptoms of vapor lock on my 2008 5.0 MPI runs like a champ till you stop for a few minutes and then no start. Let it sit for a hour or two and it runs like a champ. If I open the engine compartment when I stop it never misses a beat. I have tried idling and running blowers that doesn't work. I have checked for fuel system blockage and had the pump pressure and leak down checked at the dealer and it is perfect. Changed the water filter. If you check the pressure on the rail when it is acting up it is 0 and if you try to bleed fuel off it does not have air bubbles although due to lack of pressure it barely flows out. The pump is running but you can tell it is not pumping fuel because just before it is ready to start you can hear the pumps sound change because it is beginning to pick up liquid fuel. My theory is that it is boiling the fuel in the lines before the cool fuel box as it passes over the engine and the pump cant pump the vapor. I am going to try insulating the lines or building some heat shields but I don't think that will work. Has anyone had any success with this fix :
"you may also try adding the merc low pressure fuel pump kit to help prevent vapor lock and maybe the merc cool fuel cannister. sounds like its a fuel boiling in the lines (vapor lock) problem. remember fuel under a vacum can boil at 50*F. good luck and keep posting"
I am willing to try anything at this point because leaving the hood up attracts many fellow boaters trying to help because it looks like I am stranded. I have also considered mounting a radiator cooling fan back there somewhere to circulate air from the gunwales but I don't know exactly how to mount it yet. There is very little ventilation in my engine compartment and I am surprised more people don't have this issue.
