drun_trucker
- May 24, 2015
- 52
I finally got the boat started today, it's been a test of my patience to say the least.
I got this thing on a trade, that being said it has sat for 6 years. I will do my best to try and break down what I have done thus far.
New Items:
Trim motor replaced (irrelevant, I know)
Starter
Ignition Coil
Condenser
PreTrouble Shooting Steps:
Fuel/Water separator removed and check, was clean
Carb removed and inspected
-was beyond clean, accelerator pump was soft and plyable
Cap and rotor removed
-rotor looked brand new with no signs of wear, cap contact points slightly corroded(more tarnished) but sanded clean
Points also slightly tarnished, sanded with fine sand paper and shined up good
I got is started and checked to be sure it was pumping water. Was a bit concerned that sitting for so long the impellor would be junk, pumped water good. Had a heck of time starting it thought. I pumped the heck out of the throttle and seemed to do more harm than good. I let it set for a few seconds and it starts but won't hold idle.
Need I remind all that it's been sitting for 6 years with the same gas. I really think the gas is bad. All things look good and degraded fuel would be a good reason for the trouble. I'm not 100% sure on the capacity but the gauge shows 1/2 tank.
So 2 questions:
1) Does it seem that bad gas would be the root of my current evils
2) Can a can of SeaFoam help get me through the other half tank of gas or should I top it off with new higher octane fuel
New Items:
Starter
Ignition Coil
Condenser
So 2 questions:
