just bought a used 1996 boat with 4.3 and 2 bbl. having a very hard time starting when it's cold. tried no choke, tried choke, tried pumping it then cranking. tried cranking and pumping all with no luck. once i prime it with fuel it starts up fine. after warmed up it starts great. i'm sure i'm not getting fuel when pumping the throttle. should i be able to pump fuel without cranking motor? the carb. filter is clean. any help would be appreciated.
