Hello again, well honed the cyclinders put in new rings and bearings/ seals and put her back together . She started the second pull but I now notice my pee hole water temp is really warm. The water pump is fairly new and the stream is fine. Does the dact of new rings and honed cyclinders in conjunction with high oil to gas ration cause a change iiin water temp. Before doing all this work on motor the pee hole water was always cool,even the exhaust plane never got warm, let me know what you think, thanks
