Sunnyotaki
- Oct 20, 2020
- 2
When cruising on the plane the tilt trim works fine, at low speed when coming into shallows I raise the tilt it drops back down.
On the trailer it works as it should in neutral and various positions with the throttle forward. The motor is solid with weight applied and doesn't move so I'm guessing the hydraulics are ok.
Could the solenoids or throttle switch be faulty? But that doesn't make sense why it works fine at speed.
Any ideas?
Any ideas?
