2007 Mercruiser Mag 350 MPI fuel pressure too high.
pacopico
Hello all, I have searched here and cannot find an answer here or elsewhere on the web regarding actual fuel pressure should be when running.
I have read Mercruiser Service Bulletin 2004-06, which addresses fuel pressures, and all it say is that if when in key-on, engine-off mode the fuel pressure is above 44psi replace the cool fuel module. Well, with my non calibrated gauge in that condition I get 46psi...so really close but not exactly on the spec.
The problem is that when I start the engine and run at idle the gauge increases up to about 82psi over a period of 30 seconds, then stays there. When I disconnect the fuel pressure regulator the pressure goes up to 84-86psi. The vacuum line to the regulator is free of obstructions, and the regulator responds to the loss of vacuum so I believe the regulator is OK, however I think the fuel pressure is too high as on automotive fuel systems 30-40 psi is the normal running fuel pressure.
I did rev the engine up to about 1800RPM in neutral and the pressure remained at +/-82psi. When I stopped the engine it fell immediately to 30psi and has held there for several minutes.
What started all this is that I completed the annual service several weeks ago (replaced the fuel filter too), and ran the boat on the muffs, no problem. Took the boat out for a day, ran at various speeds (idle-planing) no problems, and went through about 15 gallons of fuel. Filled up a couple days later, putted around the lake and the engine started to misfire, and drop idle from 800RPM down below idle. I checked what I could while floating (there was fuel in the filter housing, had good battery voltage, and the pump would trigger when I went key-on for a few seconds as it should. I got the engine re-started a few times, but eventually it just ran out of fuel. The next day when at the dock I went and fired it up, no problems and ran well. I putted over to the boat launch (200 yds) and trailered the boat, no problem. My issue is that I don't want to go trial it until I get to the bottom of the problem.
Of course this was an intermittent no-run condition that hasn't re-occured, now turns into a question of where should I be on fuel pressure.
Anyone here have any ideas, or a copy of the correct portion of a service manual that gives pressures?
Thanks!
Fun Times
Hi there, You must have a Bravo stern drive and use the Gen 3 cool fuel module? If so, the actual fuel pressure should be 42 psi.
Also the service manual mentions if the fuel pressure is above 44 psi, replace the fuel regulator which is hopefully the case. Hopefully you don't have another problem causing the high pressure such as the occasional fuel module internal paint substance starting to peel blocking the underside of the regulator at minimum all the way up to causing fuel injector damage and engine fuel line/rail cleaning while injectors are out for testing, cleaning or worst case replacement.
You are looking for Mercruiser service manual number 40 available online at boatinfo.
Search online mercruiser Gen 3 fuel module paint,
http://www.bing.com/search?q=mercru...=-1&sk=&cvid=c284382959334568b3fd1b72f1661f0f
Pull and check the top cover where the regulator is mounted and inspect the whole cover (also remove the regulator) and inside the module for debris as a blocked regulator is usually the more common problem associated with high fuel pressure than a failed regulator.:(
Let us know what you find, good luck:)
pacopico
Thanks Fun Times...I pulled the regulator on the pump/filter assembly, it was packed with paint. Your link illuminated more with regards to service bulletin 2009-01, and paint flaking/peeling off from inside the assembly...which requires complete replacement of the assembly, not just the regulator. I'm off to the dealer now for a new one. Wallet lighter, hopefully the boat will run faster...
Fun Times
I hope you found it in time.
Some have had success with removing the paint both on the inside top cover and inside the tank module.
pacopico
I found it in time in that the paint did not get to the injectors. I did buy a complete new module as the raw water fittings were leaking on mine once I got in close and looked. I am keeping the old one to teardown this winter and clean up as needed on the pumps and regulator, and keep those as spares. I'm sure I could have cleaned what I have and saved a few bucks, but its' a single screw boat, and the raw water fitting leaks (and crappy design) were enough to make me pull the plug on top of the paint issue.
Also, I am not going to use ethanol fuel ever again in this boat, and will be checking fuel pressure at the time of performing my annual services from here going forward to ensure I am not operating with a ticking time bomb.
Cheers!
