Hellow everyone I have a 1993 johnson 20 hp that idles very rough and has alot of white smoke I checked for spark good both cyl did a dva test and switched coils and 2 new plugs Yet when its running and i pull the top plug wire it runs the same pull the bottom and it stops running. Comp on both cyls is 110 psi.The reason i think its the head gasket is because when I run it the base cowel around the engine fills with water and after i pull the spark plugs it looks like steam or smoke comes from the spark plug holes on both cyls for about 4 or 5 min any ideas thx for your help.
