I have 35' Chaparral with two 2006 I.B./O.B. MerCrusier 6.2 MPI engines. The problem started with my starboard engine stalling at slow speeds. However it would restart and run fine. My mechanic said it might be the Air Intake Valve that was not in stock and would have to order. Took the boat out and starboard engine died again but would not restart. Drove boat in on port engine and found a replacement Air Intake Valve at another dealer. Replaced part however boat did not start.
Mechanic said check fuses in same compartment mentioned above and middle 20 amp fuse was blown. Changed fuse and boat ran fine. (Note: Fuse had small blow and no black markings.) Ran boat for 3 hours straight no problems to first destination and stopped for the night. Started up fine and ran another hour. However we underestimated the fuel burned in first trip and ran out of gas. Once we were able to refuel bout ran fine for 20 minutes and starboard engine stopped. Checked middle fuse and it was blown with a 1/4 of the inside having black soot markings. Replaced the fuse again and turned the key but would not start. This time the inside of the fuse was completely blown. Took boat in and rented a slip.
After speaking to mechanics they said it might be the fuel pump. Purchased two new fuel pumps for the starboard engine and a fuel filter for each engine. After purchasing the pumps the mechanic said before changing the parts to change fuse, take power off of fuel pump, and start the key. This way if fuse does not blow then it is the pump that is bad. Did that and the element inside the fuse was completely gone.
Not sure if the Air Intake Valve or running out of gas had anything to do with the fuse blowing. Was hoping you could help because I am having a problem finding a mechanic in this small town. And the boat is an hour away so I wanted to be able to try a few different trouble shooting procedures when I return.
I will try what you mentioned above. In addition I read in this forum that it could be the fuel relay switch? Or is there a manual I could purchase to help with the troubleshooting?
Thanks for time and consideration.
