weekend warrior
- Aug 14, 2008
- 17
A long story short! the boat (1994 24' searay bowrider) has been laid up since 2009 due to various surgeries over the last 2 years. After the usual 2 year lay up issues, i replaced the impeller last5 week (old one looked perfect (was replaced the beginiing of 2009 also) and just replaced the thermosatat with a 160 deg today. I ran the boat with the new impeller to test for leaks and it ran well at about 170-180 deg with a thru-hull water connector that hits the intake hose prior to the water pump.
Today i replaced the tstat with a 160 deg for fear that the old one was cruddy. I was right. I cleaned the housing real well and replaced the tsat with a mercruiser 160 kit. Some idiot must have stolen the gasket with the metal eyes from the package in the store. From what i understand, the only importance of that gasket is for the audio alarm. It has not worked since i got the boat, so I assume the regular gasket will be fine. I ran the motor with muffs this time because the thru-hull connection broke as i was hooking the hose up. It ran between 170-190 for about 10-15 at idle rpms.
Well so much for a long story short, but i guess my question is: Is that a normal operating temp with muffs on and should i expect a lower temp in the actual water? Also, i believe the old tstat was a 170 and, if i remember correctly, I had a similar operating temp issue in 2009.
The engine was rebuilt in 2008/2009 (thats a whole other story) and has about 15-20 hours on it since the rebuild.
Thanks
Thanks
