1988 15hp evinrude dies after 10 minutes
moscow95
I just bought a used 1988 evinrude 15 hp outboard engine and it is in "like new" condition8). It starts at the 2nd or 3rd pull and runs great. After about 5-10 minutes at high speeds it starts to loose power suddenly and dies.I have replaced the fuel tank with a plastic one because I thought the metal one that came with it had rust or was causing my problem. It helped it run longer but it still dies after 10 -15 minutes. The model # is E15RCCS.Can someone please help me.thank you
Texasmark
Re: 1988 15hp evinrude dies after 10 minutes
Replace the ignition coil which may be part of a power pack. Easy to find as the output of it connects to the top of the spark plugs.
If you have a separate trigger circuit, go to Radio Shack and get some white thermal compound (grease). Lift the solid state trigger ckt and anything else that is in an epoxy filled case and screwed onto a sheet metal bracket or engine block and smear some grease between the component and the chassis. Remount.
Problem is heat related and both will/can do this to you . Question is, which is it?
Mark
moscow95
Thanks for the reply Mark, But Im sure that the problem is not from heat because after it dies it is not too hot.
Texasmark
Doesn't have to be too hot. The heat is inside the component and you may be able to detect it by touching it CAREFULLY.
I know you vented your new fuel tank. d:)
Mark
Jason Ortiz
power pack it sounds like it has a crack on the under side once a little heat gets to it it will cut {does it start right back up } it had sme problem
Scaaty
Yep, I'm going with a powerpack/coil too. Heat that you can't feel will torch it. Best to run it and feel the cylinders when it starts to die out. One colder than the other, a bad coil. Both same, buy a new powerpack....looking at about $125+.
Texasmark
If you have cracked epoxy or any plastic epoxy filled case components that are cracked you have your problem. The cracking comes from failure and the resultant heat escaping.
Mark
