Cloverdale77
- Mar 22, 2011
- 3
1978 Johnson 115 with all kinds of problems. It is hard to start, hard to idle, hard to accelerate. It takes feathering the throttle a lot and restarting to both idle, idle in gear, and accelerate in gear while in water. Once it does manage to accelerate in gear it will wind out to WOT and scream across the lake. The low speeds is when it has problems. Out of the water, it will start, idle and idle in gear no problems. I synchronized the engine per the Seloc manual. I cleaned both carbs and removed the jets and found no varnish or dirt. I set the floats as best I could from the manual and suggestions on here. I found that the OMC QD fittings on the supply side fuel lines were junk and new fittings leaked air within an hour of use. I just went with a hose barb for the time being until I can find a replacement QD that is not going to leak. I found that the spark advance at idle out of water was 0 degrees. The book recommends 0-4 degrees. The plugs all look good but were gapped at 0.030". I widened that to 0.040". Nice blue spark at all plugs. I have a spark checker and DVA on order to get more accurate spark readings as well as ignition system readings. Compression test was 115, 114, 120, 122. The lower being the starboard bank. Higher port. If the engine is trimmed anything but all the way in, it sputters at idle and dies easily. I found that if I pull the spark advance lever and accelerate the engine, everything is fine. If I use the quadrant to accelerate, the spark advance lever lags behind the throttle a lot before it starts to move and this is when the engine likes to die. How far should the throttle lever move before it moves the spark advance? This is frustrating as everything works out of water and putting the boat in water means I have no way to check timing and loosing tools becomes an issue. Once the spark check shows up I will be able to see if the 7/16" gap still provides optimum spark and I will see if the charge coils produce good voltage. Any other suggestions would be greatly appreciated.
Thanks in advance.
Thanks in advance.
