Re: 1972 6HP Johnson Bogging Down
Flywheel nut torque for a 1974 Johnson 6hp motor is 40 -45 foot-pounds. Your's is probably the same.
As for spark, if you're sure that the plugs are consistently firing, you are probably wasting your time focusing on the ignition system. You have a magneto/points system and even if the point gap is off a wee bit, the motor should be getting proper spark. It wouldn't be a timing issue either, because if you have the points set correctly, the motor is timed correctly. My experince with these motors, is that if the point gap is off by more than a little, the plugs won't fire at all.
If this motor has been sitting around for awhile, I would thoroughly clean and rebuild the carb. That includes removing plugs to clean the passageways. I'm also a fan of putting a small, inline filter between the fuel pump and the carb. Getting your carb clean doesn't help you, if the fuel pump diaphragm is dinintegrating and throwing crap into the carb.
