1959 johnson
pbatch
59 johnson 10 horse 2 stroke. ran great last year. seems to have no spark now. pull start is wearing me out.any ideas?
bktheking
Re: 1959 johnson
Pull the flywheel and look for cracked coils, that would be a starting point.
Mas
Re: 1959 johnson
Clean up the points and check/regap.
Mas
Re: 1959 johnson
If you literally have no spark, then the above suggestions are right on the money.
If you do have spark but mean rather that it won't start, ask yourself if you left any gas in the carb since you used it last. If so, a good carb cleaning and/or overhaul might be in order.
samo_ott
Re: 1959 johnson
Read the top secret file at the top of the forum under the no start area.
