1955 Sea King 12HP “get it running” checklist
SKREELI
Hello,
I have recently acquired a:
1955 Sea King 12 HP outboard
Montgomery Ward
Model #GG9016A
Serial #55X577504
Gale 12d11
I have been referencing this manual:
https://www.richardlpaquette.ca/GaleProducts1951-1963ServiceManual.pdf
I have not tried starting it yet. It has compression, does not have spark.
I used a spark checker and did not get spark on either cylinder. Spark plugs look okay like someone replaced them and still couldn’t get spark and gave up. I tested the spark wires with a multimeter and only got “OL” reading, so I’m thinking it’s the wires.
Both coils read about 7,300 ohms. I found an old magneto unit with spark wires on eBay for this exact motor and the description said it had spark on both cylinders and it was $20 so I figured why not and it’s coming in the mail.
I also read that it’s good to go ahead and replace the impeller so I found a modern replacement Sierra 18-3002 for $12 so that’s coming in the mail as well.
I also have a timing tool in the mail, a little confused on how to use it but I know you have to line up the lines on the flywheel.
I drained and filled the lower unit gear oil near the propeller.
I tried finding a carburetor rebuild kit, but I am having trouble identifying the part number, I kept getting recommended Sierra 18-7043 but it doesn’t look right. I will just clean the carb in the meantime.
Is there anything else I need to check before attempting to start this motor? I know the fuel ratio is 24:1 regular unleaded gas:TC-W3 2 stroke oil
I have a barrel test tank ready.
Thank you
Honorary Supreme Mariner
The timing tool is a shop time saver.----You can use the flywheel to get the same results.-----Picture of the coils and condensers?
SKREELI
I have another magneto coming that looks in better condition than this one, but I plan on fixing what I can with this and keeping as a backup.
Is there anything I can do to clean this up?
The one in the picture looks very good.----Clean and set points at 0.020 and check for spark.----Then set using the flywheel to get maximum spart at the right time.----The timing tool ( I have them ) is nothing but a " dummy flywheel " a shop time saver.
