1/8 wall tubing would be way overkill as a center stringer. I think the stringer in mine is only "0.060 or somewhere thereabouts.I read over most of your thread there BWR great job on the resto you have one fine looking boat there
I noticed your boat and other kingfishers I saw on different threads have a aluminum center stringer which mine doesn’t currently have
can’t figure out why someone would have removed that I’ve got a call in to a metal supplier about some 1 1/2x 5 1/2 1/8 wall aluminum tubing they’re supposed to call me back tomorrow
I looked for the hin where you found yours and there’s nothing there.
Another thing I noticed is that none of the other kingfishers I’ve found yet have a splashwell?
Yes, need to keep that area clear so any water can drain to your bilge.1. Does care needed to be taken so that the center drain ways under the ribs along the keel remain open
There I fixed it, you just need a light skin of the epoxy stuff to fill the pitting.Personally I use Marine Tex for how easy it sands but both will work just DON'T over do the application.
