I have a 1995 Johnson 15hp that has been running perfect with the exception of a little sputter every now and then. I assumed it was something in the carb. I was out boating on sunday when i took of and after about 10 sec the motor went to spitting and sputtering and then just died and it would not start back up. I brought it home and tore the carb off thinking that something had finally clogged it up, but she was clean as a whistle but i cleaned it anyways. i put it back together and tried to fire it up and it tried to start the first pull and that was it. I checked my fire and i was getting nothing so i was told to check the kill switch/safety kill thingy. I tinkered with it and it fired up, but is running like crap. i attempted to tweak the carb but it made no difference. I decided to check the fire and while it was running i took the top cylinder spark plug wire off and it didnt effect the way the motor was running but it was getting spark. i did the same to the bottom one and the motor would run but it was a lot worse and died shortly after doing so. I checked and i still have compression in the top cylinder so i am at a loss. I could really use some help since i just bought this motor 2 months ago and it is fishing season. thanks
