Got a 15hp Evinrude Model E15RCIS (not sure of last two letters may be 1 and a 5). S/N 0003031. Question what year is it? Also is the water pump working OK. Get a slight mist from hole about halve way down back of motor with motor running at fast idle, not in gear and in a tank. Have not had time to run for a longer time and check the head with temp gun. When I do check it about what temp should the head temp be? Would about 140f be about right? Thanks for any help.
