ranger481vs
- Aug 5, 2019
- 104
This engine has the 3 point drain system, which I haven't had before, but also am not fond of based on what I've been reading on how they can plug up. Planning to remove that in the future, but for now, I need to winterize with it on. I've already drained the 3 point system, lots of water came out out. I've also opened the 2 drain points each side of the block and had some water come out on one side due to blockage. Are there other drain points that I'm missing on this engine or other areas that I should be concerned with? Thank you.
