I have attached a photo of what I am working with and the Pawls... (Click to enlarge)
I found an older photo, but I am desperatly trying to find a photo reference for the exact Pawl placement and position for a 1988 Johnson 30hp Outboard, Model J30RCCE. (Manual Start)
If you can provide me with a url, or location, I would be sincerely and graciousply appreciative!!
(Or if someone can type me through it... Each was I put them on looks incorrect. The old Pawls were destroyed because the first shop I paid to fix the starter did not do a correct job.. So like they always say.. If you want something done right.... Do it yourself... I'm up for the challenge..!)
So from the photo..
1)Do I have the Pawls turned up the correct way (Are the tops of the Pawls facing up)
2)Which way should the offset lip face on each side? (The part that "L's" upwards)
3)And which way do the Pawls go between thepins to the outside of the Pawl (stop?) pins? (The pin to the left and right of each Pawl pin)
Thaks SO much in advance!
Brian
So from the photo..
Brian
