Next
1 of 2
Go to page
Go
Next
Last
Installed bright LED reading lights on each arch leg.
onthelake2010
Jun 28, 2010
Radar arch inside panel was rotting. Removed, installed more wiring to add lights. cleaned all the white trim and clued with marine goop to keep water
onthelake2010
Jun 28, 2010
Cut a new panel & covered with grey vinyl then installed a super bright yellow LED dome light.
onthelake2010
Jun 28, 2010
Installing high density foam under wind sheild. There was a black tack that came with the boat. I've burned my feet more than once on that stuff in ho
onthelake2010
Jun 7, 2010
Installed new Richie compass. High density foam is almost the same thickness as the compass mount.
onthelake2010
Jun 7, 2010
Trimmed. Much nicer on the feet and looks way better.
onthelake2010
Jun 7, 2010
Peddle boat being lowered. I removed one holding rod (stb side) while leaving the port side rod connected to the boat.
onthelake2010
Apr 20, 2010
Built a peddle boat lift that can raise and lower the peddle boat into the water by using the stern drive. Made two rods and installed cleats on the p
onthelake2010
Apr 20, 2010
Bench seat. Removing old material and replacing with new grey vinyl that can take the odd spill. Also makes it easier when sliding into or out of the
onthelake2010
Apr 20, 2010
Added SS hinges to keep seat in place and make it easier for access.
onthelake2010
Apr 20, 2010
I cut the plywood in half before recovering. Don't have to remove the whole bench now to get access to storage.
onthelake2010
Apr 20, 2010
Lots of wasted space in the bow of a 2755. Got tired of setting up the v-berth and taking down to use as dinette. And then having to store the extra c
onthelake2010
Apr 20, 2010
Using finnished 1x3 to frame the support.
onthelake2010
Apr 20, 2010
I removed all the carpet and fitted a 3/4" plywood to extend the platform to the edge of the seat base. This also provide extra storage.
onthelake2010
Apr 20, 2010
Added supports on each side that sits directly over the super structure so that there is access to storage below.
onthelake2010
Apr 20, 2010
Port side support for V-berth.
onthelake2010
Apr 20, 2010
V-berth, purchased a 3" memory foam from Wallmart.
onthelake2010
Apr 20, 2010
V-berth Trim installed, glue with SS screws and foam cut. The foam takes several days to expand to full size after pulling it out of the small box it
onthelake2010
Apr 20, 2010
V-berth Trim with 1 coat of clear coat. I used 1/4" finnished plywood for the boxes and closed in the port side box, leaving the center and stb side o
onthelake2010
Apr 20, 2010
New V-berth completed. Table was also cut down to allow better access to seating.
onthelake2010
Apr 20, 2010
Re-powered OMC 5.8L in 2007 with a holley double pumper.
onthelake2010
Apr 20, 2010
Map pouch.
onthelake2010
Apr 20, 2010
Finished look.
onthelake2010
Apr 20, 2010
Removed stove cover and bolted to counter. Haven't desided what to do for trim, so just used tape.
onthelake2010
Apr 20, 2010
Next
1 of 2
Go to page
Go
Next
Last
2755 Projects
28
onthelake2010
Apr 20, 2010
Updating the 89 2755 cabin.
Album information
Album owner
onthelake2010
Date created
Apr 20, 2010
Item count
28
Album privacy
onthelake2010
Media items
68
Albums
Can view media items
Everyone
Can add media items
Album owner only
Share this album
