Re: Tell me about mid-late 90's Crownline 225 bowriders.......
on a 225 I would look for a 350 MAG over a 454/7.4L or any big block for that matter, the boat will be a 55-60 MPH boat and do well on gas, Carbed over Fuel Injection, I always like Fuel Injection, but I also trailer my boat from Colorado to Lake Powell, a difference of 2500 feet or more, Fuel Injection is less problematic for boats that are used in multiple elevations. But if your a flatlander and never see a difference in elevation like I do a carb is fine, Fuel Injection can also mask issues, fuel injection has the ability to change fuel mixture to overcome problems with your motor but that very same ability allows it to solve my problem, I love Fuel Injection, my boat fires in less then 100 revolutions everytime I cannot speak highly enough about it LOVE it I highly recommend it. But I would not be scared of a carb, they are easy but intimidate people, once they are setup they are as good as FI, you don't see many high performance motors with FI.
SO on a 225, a 350 MAG and even 5.7(same as a 350 Cubic Inch wise) will have similar power, in fact spec wise a 350 MAG will have the exact same HP as a 7.4L MPI but the 7.4L MPI will have the edge on torque but you are looking at a smaller boat(then mine) so torque is not as big an issue as it would be for me, but your at the limits for a small block, still well into the mid 50 MPH range and possibly low 60's with props, the Bravo 1 will help your top end out as well and will do fine at the bottom(getting out of the hole).
Fuel wise is more on how you drive it, the small block will drink less then a big block unless you drive it like I do, I'm in Law Enforcement and thats how I drive so I get used to paying for gas for me its a non issue, big boat big motor big gas money, but either can be fuel efficient depending on how you drive it.
For me I would look for a 225 LPX with a big motor, man what a rocket 60MPH+ but for you and watersports a 225 with a 350 MAG, a Bravo III and a tower would be bad *** and actually a very popular boat, still talking mid 50's MPH wise, get out of the hole like a beast even with two tubes or better.
the boat you are currently looking at, 454 with a bravo 1 will be a boat that may hit 60 MPH and will certainly do 60 MPH with a prop, the outdrive will do better on the top end but the Bravo III will have an advantage at the bottom, nothing wrong with a Bravo 1 but thats the difference, Bravo one is a top speed(top end) outdrive and the Bravo III is a bottom end drive (getting out of the hole). 454 indicates that it is a carbed motor so depending on the year you may need to get the carb rebuilt not a big issue couple hundred dollars every 5 years or so and she is brand new, the 454 is a solid motor but its a beast (its heavy) and it will use more fuel, Yeah yeah you could be real diplomatic and save fuel BS you know it your going to let the big dog eat.
I honestly was looking at 225's when I found my 248, great boat and you will be hard pressed to find a boat that looks more like a sportscar on the water. I think knowing what I do now I nailed it with a Fuel Injected 7.4L MPI, my wife drives my boat and the FI is a big part of her success it is so responsive, she was never as confident with my last boat which was 6' smaller and had a carbed 350, so go figure you would think going so much bigger she would struggle but the Fuel Injection is what I think makes her so happy driving, that may be an issue to think about as well, I can't tell you not to look for a fuel injected boat, I think FI is a serious advantage, unless you want a 70 MPH boat then a carb is your answer, and yes Crownlines do 70+ built right.
I think I have rambled enough, hopefully your not more confused LOL
